Lifters
The lady in my life drives a 2000 Mustang convertible V6, when the motor gets all warmed up on a hot day I start to hear what sound like a lifter knocking, I have the oil changed every 3-month 5W-50 as reccommended.
Does anyone else have this problem and what is the solution.
I'm thinking it's the oil so I may go to a higher V say 20W50
Hey ,welcome to the forums!!!!!!!!!!!You'll find alot of good tech info on here but you might want to post this in the tech section where peolpe with a little know how will see it.Anyways Welcome and have fun
I wouldn't suggest using an oil system cleaner. They can destroy engine seals and the gunk that forms that holds your engine together. Higher viscocity oil may help but most likely if the lifters are tapping then they have lost there prime. They have to be replaced if they have lost there prime or you will have poor performance.
