wheel studs
Old May 26, 2005 | 11:09 PM
Sickspackstang's Avatar
Sickspackstang
Default wheel studs
guys i need help, i have a 98 V6, and my front right wheel is kinda stuck on. one of the bolts stripped out and the wheel stud spins with the bolt. is there a way to only replace the studs if i grind the last stud off and have 4??? please
Old May 27, 2005 | 09:17 AM
wiseguy's Avatar
wiseguy
Default RE: wheel studs
If the splined portion of the stud is chewed up but the hub is fine, then you just replace the stud. But if the stud opened up the hole in the hub, then you're going to have to replace the hub. You've just got to get that one stud out, that's going to be the tough part.
Old May 27, 2005 | 06:46 PM
ZachW04Stang's Avatar
ZachW04Stang
If the stud has stripped out part of the hub you should replace the whole hub assembly.
Old Jun 5, 2005 | 10:16 PM
bobbyo's Avatar
bobbyo
I'm not an expert on this but if the stud to wheel fit isn't too bad, I'd be inclined to butter-up the spline with JB Weld metal repair epoxy and remount the wheel to align the stud off the others. Let the exopy cure and torque the associated lug nut to specification.
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
