Gasoline
Depends. After running regular for the majority of my cars life, after running a couple tanks of Shell V-Power through her, it got a little more "spunk" and seems like its happier. But gas mileage, didn't notice a difference.
Sooo, in a nutshell, just using regular and fuel treatment every once and a while will clean the engine just as well I guess.
don't listen to anyone, get the super. you're only paying 50-70 cent's more from feeling the tank. but the higher octane number means the cleaner it is. actually the best gas would be the kerosene which is like 98 octane. anyway the higher the octane # the longer you car will run.
if your car doesn't ping on regular then it is a waste of money to put higher "octane" gas in it
go ahead and put kero in your car. it won't run. kero is for jet or diesel ignition. Kero would have about a 150 Octane rating or more and if it was used on combustion engines it would use the Cetane rating not the Octane rating. do us a favor and don't post tech again
If your worried about trying to clean your engine or anything like that, try to seafoam it the next time you change out your oil. You didn't state in your post that it's one of your concerns but it seems like vovovovan was trying to tell you other wise. Put 1/3 in your crank case, 1/3 in your brake booster hose, and 1/3 in your tank. Other wise don't pay more for gas that has 0 effects on you.
Professor Wizard
Jun 14, 2006 03:39 AM
