Missfire Need Help
Old Nov 16, 2008 | 10:17 PM
yaro232's Avatar
yaro232
Default Missfire Need Help
i got an 01 V6 with a troublesome misfire. Coil,wires,sparkplugs,have been replaced. Misfire is only on cylinder #1. I have ran fuel injector cleaner, along with seamfoam at different times. Seafoam was done at the manifold,crankcase,and fueltank. Fuel filter has also been replaced. Car has about 130K miles on it. Any suggestions would be great. All sparkplugs have been gapped to .65 to accomadate the deamon coil.
Old Nov 16, 2008 | 10:34 PM
RonnieD's Avatar
RonnieD
Try to run a compression test on all the cylinders and compare #1 to the other 5. at 130k miles its not a bad idea.
Old Nov 16, 2008 | 10:41 PM
yaro232's Avatar
yaro232
It wouldnt be a bad idea, at 130K makes sense. thanks for the tip
Old Nov 16, 2008 | 11:03 PM
RonnieD's Avatar
RonnieD
keep it simple first, you need compression, spark, and air/fuel to create a combustion.
You seem to have elimnated the spark side of the 3, check compression, if youre not having any problems or differences in that area, then i would start checking for issue in fuel delivery.
Even though you changed out most of your ignition side, what does the plug in #1 look like?
HendersonDavid
Sep 9, 2009 05:32 PM
BC 00GT
22
Jun 4, 2009 06:56 AM
MustangHitz
Feb 12, 2009 04:53 PM
Topgearhead
Jan 6, 2009 03:54 PM
Captain Drew
17
Aug 17, 2005 12:51 AM
