Cdc Shaker Intake + m112??
Trying to make more power with smaller pullies. Or installing a blower on a motor that might not be in top shape to start with.
Driving without a tune is one of my favorites to see happen. One guy was racing his without a tune.
soooo, how about a car with 90k on the clock, a full 2.5" exhaust with LTs, and either a 25% (id do the 42 if someone other then RPM outlet has them) and a 3.10 upper?
As for the tune, you have to get the right air/fuel mixture correct with the added air, not too lean and not too rich. Reset the idle, part and full throttle response, MAF and fuel injectors calibrated, etc. Your tuner will edit these values on his laptop while hooked up to your car.
Tuning just makes sure all the parts are working together correctly. Mostly, it's making sure the amount of fuel matches the amount of air at any given RPM. A dyno tune is a dyno tune.... no matter what changes you make. It's usually a flat rate per hour - depending on the shop.
What they will do it montier the Air / Fuel ratio, and then adjust timing and fuel to make sure the spark, air and fuel spray are all happening at the right intervals.
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
