Help with squeaking noise
Old Jan 21, 2009 | 05:59 PM
v699mustang's Avatar
v699mustang
Default Help with squeaking noise
Hey guys I don't know too much about cars and I need some help. I think it may be the tires but I recently got them replaced so I think it may be something else. Every once and awhile, usually when I am pulling into my drive way (making the car be uneven from going up uneven concrete) I hear my car make some weird sounds, it sounds like it is squeaking. Anyone have any suggestions on what I should do?
Old Jan 21, 2009 | 08:03 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
It's either balljoints, control arm bushings, tie rods, or spring insulators. If you have over 70k mi then you need to replace you balljoints anyway, which is most likely the culprit.
Old Jan 21, 2009 | 08:58 PM
alkureg's Avatar
alkureg
is it a squeak when you move the suspension (going over a bump) or only when you get on the driveway?
when i dont go up my driveway perfectly straight the slight body bend kind of groans, but listen to ryan fo sho^^
Old Jan 21, 2009 | 08:59 PM
alkureg's Avatar
alkureg
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
ccdguy
Sep 19, 2015 05:20 PM
