Need UDP help ASAP
Old Aug 18, 2009 | 08:59 PM
SilverBullet09's Avatar
SilverBullet09
Default Need UDP help ASAP
Ok so I have a 42% UDP and a bad harmonic balancer to go with it. Is there any way to remove the stock harmonic balancer and use it with the aftermarket pulley? Thanks for the help. Oh and this is for an 01
Tom
Old Aug 18, 2009 | 09:04 PM
Fink's Avatar
Fink
Is your engine internally or externally balanced? They changed how the engine was balanced halfway through 01 I believe.
Old Aug 18, 2009 | 09:15 PM
SilverBullet09
01s are externally balanced
Tom
Old Aug 18, 2009 | 09:19 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
No, the factory ones are actually milled off in order for the aftermarket ones to bolt up. I'd call RPMOutlet and see if they will warranty it.
Old Aug 18, 2009 | 09:55 PM
l_shizzle_l's Avatar
l_shizzle_l
4 bolt or 3 bolt pulley?
Old Aug 18, 2009 | 09:56 PM
cominus's Avatar
cominus
Lmao!
They have a bad reputation for having bad customer service but good luck anyways!
Old Aug 18, 2009 | 11:47 PM
RyansQuick6
Reverse Gear Member
They've been really cool with me
Old Aug 19, 2009 | 10:43 AM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Hey does anyone know where you can get a 42% for a 94-98? RPM only shows have 25% for those years unless Im reading something wrong here....
http://www.rpmoutlet.com/musv6asp.htm
Thanks,
Matthew
Nick Oliver
Oct 17, 2018 04:22 AM
DJ Piner
Sep 30, 2015 03:03 PM
fireboss343
Aug 21, 2015 06:25 AM
kirk35
Aug 17, 2015 08:42 PM
MelloYello
Apr 23, 2004 03:59 AM
