Wheel Differential?
yea i know that but it will save me money if i buy the GT axle, which it all ready has a tlock. if i order one for the 7.5 it is gonna cost me like 209.99 extra dollars.
and what years can i take the 8.8 axle of a GT. my car is a 2000 v6 automatic. and does it matter if the GT is auto and manual?
well the car was making a noise in the back wheels when i bought the car, i took it to the mechanic but they did not found anything, but i knew there was something wrong. Over time the car was making the noise more often and its really loud. I took it to the mechanic again and they told me that the part in the center of the axle was damage(the center where the gears are)
Yeah but that isn't the diff, those are all seperate. Spider gears go in the diff, and ring gears are bolted to the diff. A differential is just a case that holds the spiders and ring gear and sits between the shims and bearings. They don't wear out. If something is broken, then they would have still had to open the cover to see what it was. If it's a pinion seal, then that's just about and hours work, seal and fluid.
R&P's don't really wear out too often either. They're either messed up from the start or last 400k+
whatever, good luck, and let more **** mechanics sell you stuff that doesn't exist or doesn't go bad. Just don't buy the gold plated muffler bearings, standard polished stainless will do fine.
jwog666
Dec 27, 2021 08:09 PM
KingRando
Oct 2, 2015 08:06 AM
mungodrums
Sep 28, 2015 10:54 PM
