Air Temperature Sensor
Old Jul 20, 2005 | 04:45 PM
mgstang's Avatar
mgstang
Default Air Temperature Sensor
Where exactly is the Air Temperature Sensor or Coolant Temperature Sensor on a 2004 V6. I'm so confused, I've looked everywhere. Any help would be great thanks!
Old Jul 20, 2005 | 05:00 PM
The Great Cornholio's Avatar
The Great Cornholio
I ♥ Acer
Default RE: Air Temperature Sensor
The air temperature sensor (IAT) is integrated into the MAF sensor unit, mounted right behind the air filter box.
Old Jul 21, 2005 | 03:53 PM
mgstang's Avatar
mgstang
So if I was piggy backing a chip onto the air temperatue sensor, I would use the the cords that run into the MAF which is connected to the air filter box.
Old Jul 21, 2005 | 05:32 PM
The Great Cornholio
I ♥ Acer
I wouldn't tie anything directly into that harness. The MAF sensor output is one of the major parameters affecting the performance of your car and splicing into anything sharing the connector to it is not something I would do. A performance chip is typically tied directly into the ECM located behind the passenger-side kick panel. I use a flash tuner rather than a chip so excuse my question if it seems foolish, but what kind of chip requires a tie-in directly to the IAT and/or coolant temp sensors?
Old Jul 21, 2005 | 06:59 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: mgstang
You're not considering one of those 'Just plug this 'whatever' into your MAF or Air Temp Sensor and gain 20+ HP' are you? They're junk. Don't mess with the MAF unless you have a handheld programmer and dyno to see what effect the changes have or you could have some serious problems.
Old Jul 22, 2005 | 02:03 AM
ZachW04Stang's Avatar
ZachW04Stang
All your doing is putting a resister on the iat so that its sending back a lower voltage than whats read. Its tricking your car to run rich pretty much. I wouldn't suggest doing it, your car will run too rich and you will just clog up your cats. I doubt you will see any performance gain at all from doing this anyway.
Old Jul 22, 2005 | 05:24 PM
mgstang's Avatar
mgstang
Good Call thats exactly what I was gonna do. Thanks for the advice, I'll just sell it on ebay.
Jb145700
Aug 21, 2022 06:37 AM
jwog666
Dec 27, 2021 08:09 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
svfetter
Oct 5, 2015 11:39 AM
TfcCDR
Sep 14, 2015 12:08 PM
