UDP install question
Old Jan 24, 2010 | 12:15 AM
Harty123's Avatar
Harty123
Default UDP install question
Hey guys i am looking into getting the 42% motoblue UDP.
I know i can install this myself. at least at home, but i am living at the dorms and all i have is a small tool-kit I have in the trunk for basic stuff.
Can anyone give me the specifics on how easy or hard this is?
Old Jan 24, 2010 | 09:23 AM
JKs95stang's Avatar
JKs95stang
There is a sticky on installing pulleys, check it out here https://mustangforums.com/forum/6-cy...d-how-tos.html #5
Old Jan 24, 2010 | 09:27 AM
Shaunmac9128's Avatar
Shaunmac9128
I don't know if you technically "need" one, but you should go to autozone and rent a pulley puller to make it easier.
Old Jan 24, 2010 | 08:21 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
you NEED a pulley puller. I'd also recommend getting a longer bolt, you use it to get the new balancer started on the crank, and then just replace it with the stock one.
Old Jan 25, 2010 | 07:05 AM
neo8222's Avatar
neo8222
yeah you NEED one i tried to pull the power steering pump pulley without it and well u can see it doesn't work....
(i know u don't pull the power steering pulley for the asp but it's a example of what happens with shortcuts.)
Old Jan 25, 2010 | 05:10 PM
JKs95stang's Avatar
JKs95stang
Yes sir, you definitely need a puller, use the collars to pull it (there is an oval side and a round side, use the round sound against the pulley, will make sense when you see it,) and the other tool is to push it back on(long bolt as stated).
drfister
May 3, 2018 10:38 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
toastintx64
Aug 29, 2015 05:12 PM
whatsup62
Aug 29, 2015 01:25 PM
Shifty Magoo
Aug 25, 2015 03:08 PM
