Running Rough...Gimme your thoughts
Old Aug 19, 2010 | 09:16 PM
v6stang07's Avatar
v6stang07
Default Running Rough...Gimme your thoughts
So my mustang is about to hit 178k but it is still running strong; but sometimes it takes a while to get warmed up.
I have been noticing that in the heat if I run lots of errands, say crank my car up like 4 times in an hour that my engine misses a few times and starts running a bit rough. Sometimes its not bad but the other day it almost cut off and it took a good 45 secs till it got running smooth and I could drive it. I have noticed that cranking the car without the air on helps out tremendously with this problem but I shouldn't have to shut my air off every time I want to start my car. Any suggestions on a fix or where to start looking.
It only happens when it is really hot, which it has been a lot lately.
My fuel pump is only 4 years old and like 25k miles on it
The IAC should be fine but I should prob take a look at it
fuel filter and air filter are clean
Old Aug 19, 2010 | 10:08 PM
brent4's Avatar
brent4
When was the last time you changed your oil, oil filter, spark plugs, and plug wires?
If its due for an oil and spark plug change then run some seafoam through it.
Old Aug 21, 2010 | 11:39 PM
v6stang07's Avatar
v6stang07
plug wires are about 30k old but they should be fine they are napa golds. plugs I guess I could look at, they are also about 30k and are pretty nice dont remember what exactly
Old Aug 22, 2010 | 12:04 AM
Daehawk's Avatar
Daehawk
dirty cats?
Old Aug 22, 2010 | 04:57 PM
v6stang07's Avatar
v6stang07
Thats prob exactly what it is!
Got rid of them years ago though...haha
Old Aug 23, 2010 | 12:48 AM
Daehawk's Avatar
Daehawk
lolz
doh
Old Aug 23, 2010 | 06:36 AM
MustangSally94's Avatar
MustangSally94
dump a can of seafoam in it... pull ur plugs out and clean em up a bit...make sure they are still good... get a little brush and clean the wires out and put some fresh grease on the ends of the wires
bjdutch2005
Mar 24, 2017 03:38 AM
2007StangV6
Jan 28, 2016 06:09 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
zachary1988
Sep 4, 2015 03:04 PM
cbird1177711
Sep 2, 2015 08:51 PM
