Help with mods!!
Old Dec 18, 2010 | 01:29 PM
  #21
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Have fun doing that gay-ge face, you're gonna hate it, the needles don't like going back to where they belong if you don;t know what you're doing.
Old Dec 18, 2010 | 09:14 PM
  #22
Robobble's Avatar
Robobble
Don't bother with the halos. I made that mistake. They don't light the road for **** and they look stupid at night, and ok during the day. Stick with the stocks and go HID.
Old Dec 18, 2010 | 10:36 PM
  #23
NeoTokyo's Avatar
NeoTokyo
My 01' came with American Muscles dual halo Projector headlights and while they are very very bright, thats the only good thing I have to say about them and I will list what I dont like.
1.) Fogs up badly
2.) Halo's burn out and cant replace.
3.) They are NOT fully plug N play, some wiring needed and unless you do it right your going to have shorts when it rains.
4.) The plastic is cheap and damages very easily, mine look blistered, flaking.
5.) The rubber strip comes off easily over time and needs to be re-glued.
6.) They are heavier than stock.
7.) I dont like the looks too much.
So for the ONLY ONE GOOD THING there are SEVEN bad things.
Old Dec 18, 2010 | 10:37 PM
  #24
NeoTokyo's Avatar
NeoTokyo
btw, I had (Sold those POS's) another set of 1pc. dual halo projector lights on my 95' and I had the same problems.
Hell I even had the wires heat shrinked and I still had shorting because the rubber bulb bucket didnt fit too well to the housing.
I also have friends that have tried and hated these, so I have pleanty enough experiance with these to give them a "STAY THE HELL AWAY" rating.
Old Dec 21, 2010 | 11:19 AM
  #25
Robobble's Avatar
Robobble
I had those same ones from AM and I agree with everything you said except for the brightness thing. I put the $20/ea silverstar halogens in there and I couldn't see a god damn thing.
Old Dec 21, 2010 | 12:00 PM
  #26
Fink's Avatar
Fink
Smoked w/ Silverstar Ultra's FTW.
Im gonna try and pick up a spare set and do HID retrofits.
Old Dec 21, 2010 | 12:39 PM
  #27
Shaunmac9128's Avatar
Shaunmac9128
I remember someone on V6p did a retro awhileee ago and the output/cutoff was so amazing compared to my stock ligts. He was doing sets for $400 plus shipping or something like that.
Old Dec 24, 2010 | 10:14 PM
  #28
B4TM4N's Avatar
B4TM4N
thanks for the input guys.
just bought a black billet grille set, and a third brake light decal, and an 8 in ant.
might stay away from the fog lights due to have to purchase the wiring harness and money is somewhat tight right now.
just bought a CAI and am looking at HID lights to replace the ones i have now.
-B4TM4N
Old Dec 24, 2010 | 10:42 PM
  #29
Shaunmac9128
DDMtuning is supposed to have good HID's as far as cheap sets go.
Old Dec 25, 2010 | 12:54 AM
  #30
Fink's Avatar
Fink
-B4TM4N
If you know anythign about wiring, you can make your own harness. Its rather simple after you figure out the relay.
All you need is some wire, a relay, shrink tube, connectors and a switch, if you want a switch. You can run a fuse but I was told not to since I have a relay and that is basically a fuse.
