Suspension - what's wrong?
Old Feb 21, 2011 | 11:26 PM
  #21
v6stang07's Avatar
v6stang07
shouldn't the bolts for the bushings only be threaded about the first half inch to avoid over tightening
Old Feb 21, 2011 | 11:42 PM
  #22
NewEdgeStang00's Avatar
NewEdgeStang00
Originally Posted by RyansQuick6
Ok, you missed the boat on figuring that one out.
You're not supposed to tighten suspension components with bushings unless the weight of the car is on them otherwise they bind
Oh ok I understand now, sorry I'm still getting used to understanding the placement of everything under there - I'm still having to rely visually on everything. I had to search for diagrams to understand my way around there so I don't know the names of all the parts, just what they look like lol.
But yeah I wouldn't know how tight they did because I didn't handle the suspension myself, I had a shop install all the parts for me. (Shocks/struts, Springs, steeda bumpsteer skit, CC plates, polyurethane bushing) had them do it all at once. But even though I had a shop do it for me I still read through the installation guides and study the diagrams to make sure I have an understanding of how it all works.
Still learning
Old Feb 22, 2011 | 02:35 AM
  #23
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
They can be torqued to spec and still cause issues if th suspension was already in a bind. You can put the car on stands, which HAVE to be on the control arms so that they are properly holding the weight and loosen and then retighten the control arm bolts. If you've put a decent amount of miles on them, then the bushings are probably shot anyway.
If you want to go ahead and swap out the springs, just read the sticky. For what you spent having it done, you could have bought all the tools you need, including an impact and small compressor
Old Feb 22, 2011 | 09:04 AM
  #24
NewEdgeStang00
I had new bushings installed along with everything. They were the aftermarket polyurethane suspension bushings from AM. But yes I just didn't have the time to undertake this myself since I'm a full time student and music teacher in the evenings. And no garage to work in so I can't do at night. But during the day I have an hour of free time, after school and before work.
Old Feb 22, 2011 | 09:07 AM
  #25
NewEdgeStang00
But btw thanks for your advice Ryan, checking that lower control arm bolt would take me only a few minutes so that's something I can check out first
Dokilar
15
Oct 16, 2015 08:13 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
