Dead Mustang
My son has a 2003 mustang with the v6. It has always run well, until this evening. He went to start his car and turned the key on. At first everything turned on like its supposed to. When he hit the starter it went dead. We jump started the car and let it run for about 20 mins. We shut it off and tried to restart it, but it did the same thing.
It has an optima Red Top battery that was installed about 3 months ago. The only work done on it recently was an oil change yesterday.
Would the solenoid cause this issue??? I don't think the alternator would cause this, but I don't know.
Quick replies would be appreciated as I need to get it running before the morning.
This could go either way, best thing to do is to purchase a multimeter, check the voltage at the battery with the car off and then again with the car running.
Also clean the crap out of the battery terminals, I had similar problems with my 04, car wouldn't start and battery wouldn't take a charge from the alt, turned out to be a small amount of corrosion in the negative connection to the battery.
Sorry it took me a while to get back to this post. You were all pretty much spot on. Ended up being bad connections at the battery. They didn't appear to be excessively dirty or loose. I cleaned them and reconnected them and everything is back to normal.
Thanks for your inputs.
Jskeezy84
Sep 8, 2015 01:40 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
