Replace 1998 shift bulb?
Old Jul 31, 2015 | 08:24 AM
RockmanZ3R0's Avatar
RockmanZ3R0
Default Replace 1998 shift bulb?
Hello, I tried searching everywhere for an answer, and all I get is results for 65's or 2004+ or other vehicles.
I am replacing the HVAC bulbs out with LEDs and since I will have the shifter bezel and center console pulled apart I wanted to go ahead and make the gear indicator bulb match everything else. As said, I cant find any answer on HOW to change the bulb out.
Does anyone know how to replace the automatic shifter/gear indicator bulb?
I have a 3.8L V6 1998 mustang.
Old Jul 31, 2015 | 08:57 AM
Archion's Avatar
Archion
There is just a light socket under the shifter. You have to pull the console to get to it. You can't change the color as the shifter has a lens.
Old Aug 1, 2015 | 11:06 PM
RockmanZ3R0
Many thanks! -- Im hoping the lens is like the one behind the instrument cluster (Yellow bulb, blue lens, changed bulbs to white LEDs, got blue light )
Old Aug 9, 2015 | 08:00 PM
RockmanZ3R0
So... how do I pull up the console? I have looked and looked for screws, bolts, etc and find nothing. I removed the cupholder, found a wire that leads to the shift but thats it. I cannot get this darn thing off!! and yes, i have removed the trim that houses the cig lighter outlet.
Old Aug 11, 2015 | 07:48 AM
BabyGT's Avatar
BabyGT
The shifter surround pops up, it's just clipped in place, you might have to unbolt shifter to get at bulb if you have larger hands
Old Aug 11, 2015 | 01:27 PM
Archion's Avatar
Archion
This is from memory, so I might have missed a step, but it should be close enough:
To pull the console, ****** out the aforementioned trim bezel. Under there at the bottom of the dash stack you will find 2 torx screws, pull those. Open the center console storage compartment, pop out the two rubber plugs at the front of the tray, there are two Phillips screws under them, remove those and then lift out the storage bin. Under that there are two more torx screws. Lift the e-brake all the way up. The grab the real of the console and lift towards the dash. You should be able to wiggle it out from there.
Old Aug 11, 2015 | 04:22 PM
BabyGT's Avatar
BabyGT
He doesn't need to take the entire console out to get to the bulb in the shifter.
Old Aug 11, 2015 | 05:07 PM
Archion's Avatar
Archion
"Have to". No, but depending on dexterity and hand size, it may be easier for him then wrestling with the shifter and trying not to mess up the plastic slide/guard. He asked how to get the console up, so I answered.
Old Aug 12, 2015 | 09:09 AM
RockmanZ3R0
Im pretty sure the slide guard is missing anyway lol. There is a lot of work I need to do on the car, just lack the know-how and terminology. Thank you for all the help, Ill go out and fiddle with it some more and report back when possible.
Old Dec 9, 2015 | 05:56 PM
RockmanZ3R0
Just a quick update, I had to pull up the center console, there was just no way to access the torx screws without doing it, and the bulb itself was in the deepest part of the shifter area so it took quite a bit of bending of hands and tools to pry the sucker out and replace the bulb. Regardless, here is the result. http://i20.photobucket.com/albums/b2...3/DSC00785.jpg
5.0muscle
Jan 11, 2016 01:17 PM
Mustangmalo
Sep 6, 2015 05:22 PM
5.0 kevo
Sep 3, 2015 06:24 PM
