Molding Removal
Old 10-16-2015, 01:46 PM
vbonina
vbonina's Avatar
Default Molding Removal
Does anyone know how to remove this piece of molding so I can fix a leak in the top?
Thank you
vbonina is offline
Old 10-18-2015, 09:05 AM
bonestock2000v6
bonestock2000v6's Avatar
Not really a fun process but not super difficult. You have to remove the rear seats so you can pull back the interior side panels (the big pieces with speaker covers). They should only be attached with some clips and trim push pins. Next pull off the thick weatherstripping that sits at the bottom of the rear windows, exposing 2 screws on each side that hold on that metal u trim piece. Make absolutely sure you use a magnetic screwdriver or are very careful because it is near impossible to retrieve the screws if you drop them. After that, open the trunk and remove the screws holding the piece onto the back. Note the bar comes apart into 3 pieces
bonestock2000v6 is offline
Old 10-18-2015, 03:06 PM
vbonina
vbonina's Avatar
Thanks for the reply.
That's what I was afraid of. I played with it a little this weekend, and was able to feel a small split in the top (abt a 1/4") that I could touch with the top half up.
I was able to get a patch on it and tested it for leaks. So far it worked well.
Not being lazy, I'll do anything not to have to take off that molding.... LOL
Thanks again for the reply
vbonina is offline
Old 10-18-2015, 08:55 PM
bonestock2000v6
Oh I completely understand. I only took mine off cause I replaced my entire top. Which isn't exactly a quick job. Glad you got it fixed!
Old 10-18-2015, 11:34 PM
Urambo Tauro
Urambo Tauro's Avatar
(oops, accidental reply; meant to post in another thread)
Urambo Tauro is offline
stangxtreme
10-24-2015 09:42 AM
lincolnshibuya
10-12-2015 09:35 AM
jc409
Convertible Tech
09-24-2015 03:38 PM
bconboy
09-24-2015 01:55 PM
AMAlexLazarus
AmericanMuscle.com
09-23-2015 01:14 PM
Quick Reply: Molding Removal
