Brake fails
Old Aug 2, 2018 | 05:37 PM
Shubzbista5's Avatar
Shubzbista5
Default Brake fails
I have a 98 mustang and the brake failed all of a sudden and then started working again so I tried changing the brake pads I could change the front one but on the rear I couldn’t bleed it. But even with the new brakes it still stops working all a sudden and starts working again. And also I can’t change the gear shift from P to D. Somethings it just doesn’t clicks
Old Aug 2, 2018 | 11:08 PM
08'MustangDude's Avatar
08'MustangDude
Banned
Have the hydro-boost unit looked at. Brakes are assisted by the power steering system.
And for the shifting from P to D, would be the interlock.
Old Aug 3, 2018 | 07:58 AM
GT Nate's Avatar
GT Nate
could be the master cylinder having a leak get past the seals. Had one on my Riviera...would brake just fine, but every 10th or so brake push it'd got almost to the floor. New MC made all the difference. Also check for any vacuum leaks...
Not able to bleed rears... could be the proportioning valve or just gunk in the rear lines... or bad rear calipers...
Old Aug 3, 2018 | 09:27 AM
99GTvert's Avatar
99GTvert
is my username.
So is the rear bleeder screw just stripped or corroded? Because if you can verify there is absolutely no air in the system then that would at least eliminate one issue.
slick66stang
Feb 21, 2012 10:00 PM
camaroeater
Feb 27, 2011 09:31 AM
94ponycar89
Oct 22, 2009 02:31 AM
BladeX10
Mar 6, 2009 08:15 PM
bigtinybob
Jan 15, 2008 09:41 AM
