Automatic Starting off the line
Old Dec 8, 2005 | 07:17 PM
  #31
cobra232's Avatar
cobra232
Default RE: Automatic Starting off the line
ORIGINAL: mustangman02232
ORIGINAL: cobra232
ORIGINAL: 03mustangdude
so when do you do the d-2-d thingy, at what speed is it good to go into the 2, does it waste gas?
where ever your car shifts into 2nd while under wide open throttle. it should be around 4800rpm's at about 4600-4800rpms while accelerating in 1st pull the shifter down into second from drive and leave it there till you wind 2nd out to about 5000 then upshift it back into drive
it has no affect on gas. it should only be used for racing anyways. normal driving just let the tranny shift itself
so you fall out of the powerband, these engines can handel more than 6k rpm, so make them shift there, hense, you start in first, go to second, and so on, now ill brb about the O/D thing
edit: link
https://mustangforums.com/m_824871/m.../tm.htm#828651
google is being gay right now and all the sites are blocked by a firewall, so i will try when i get home
they won't even rev to 6000 with a stock computer and if they did you would be wasting your time above 5000rpm's anyways. these engines reach peak HP at 4800-5100
i have line pressure tested these trannies with the O/D on and off and there was no difference in line pressure whatsoever. this urban legend has been floating around for a few years and is not true. EECIV and V are "learning" or adaptive trannies. they will learn to shift according to your driving style. softer if you drive slower and lower in thr rpm's and faster and higher in the revs if you drive agressive. my 98 shifted soft and about 4200rpm when we first got it. after about 5-6 months the car shifted at 5200 or right at redline.
just try the D-2-D shift instead of arguing with me over it for god sake you will see i am right
Old Dec 8, 2005 | 07:39 PM
  #32
redass02gt's Avatar
redass02gt
EXTREME Moderation
just do a neutral drop at 4500 rpm. stop arguing and try it for god sake.
Old Dec 8, 2005 | 08:47 PM
  #33
mustangman02232's Avatar
mustangman02232
ORIGINAL: cobra232
ORIGINAL: cobra232
edit: link
come over to assachussets and risk your tranny on it, im not trin that cause it sounds like a good way to fug ur tranny up, and they make peak HP at 5200 rpms, which means you want the car to shift and come back into the powerband, not shifting at the powerband
ORIGINAL: redass02gt
buy me a new tranny and ill video tape it
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
drfister
May 3, 2018 10:38 PM
CarrieS
Sep 1, 2015 01:00 PM
Aug 24, 2015 01:54 PM
