255/45/18's ?
Hello, Is anyone out there running 255/45/18's on 9" wheels? I have a 2004 (All Stock) mustang vert, and I just purchased new wheels. They are 18x9 AFS wheels. All 4 wheels are the same. I was wondering if 255/45/18's would work, or are they to tall? I would like as much sidewall as I can get. I have other options on sizes, but I haven't seen much talk on 255/45/18's. This size would give me about a 4.5" sidewall. Thanks for your help. Drive-On
I'm sorry, You said you have 245's? Do you have 255/45's? The picture of your car looks good. What is the actual size of your tires in front? Can you please give me all (3) dimensions of your tires, Width/Sidewall/Size. Thank You. Drive-On
Thanks for the advice. If anyone actually has 255/45/18's please let me know. I am worried about the profile (45). I wasn't sure if the tire would be to tall and maybe throw off the speedo or the computer. Drive-On
Yes, going with 45 sidewall will throw off your speedo because the overall wheel/tire size is bigger than stock.
You are supposed to try to keep the overall wheel/tire size the same from stock 245/45/17......to somthing like 255/40/18s. I would recommend going with 40's.
Especially if you plan to lower your car at all....
Thank You. A (40) profile seems to be the tire of choice. I will stick with that. I also found out ,that the wider the tire, the taller the side wall will be, even with the same profile (40). So a 275/40/18 would have a taller sidewall than a 255/40/18. Thanks again to all. Drive-On
bazguitarman
Aug 19, 2007 12:30 PM
Kwiatkowski18
Aug 6, 2007 06:22 PM
