Well........
Old Nov 26, 2007 | 11:36 PM
LilRoush's Avatar
LilRoush
Default RE: Well........
ORIGINAL: jthorn9
I have a bad rear brake caliper and I'd much rather upgrade everything than just replace with expensive stock parts
94-04 Cobra brake conversion kit - $986 after discount
Drilled and slotted 13" FRPP front rotors - $196
Drilled and slotted 11.5" FRPP rear rotors - $178 after discount
Install - approx $600 (may do myself around Christmas or maybe before, doesn't take as long to do as H/I)
Can you explain this? What does the original $1000 get you if you still need to buy discs? You can get the front upgraded lines, calipers, discs and pads for like $400. The rear is just the larger discs and new mounting brackets for the stock calipers.
And do the install yourself. It takes about 2 or 3hours to do the whole thing. It's a very straight forward project.
mlcrycc
Jul 17, 2008 10:08 AM
tino
Mar 1, 2008 07:05 AM
apbt426
Jan 10, 2008 10:32 PM
0NF1R
Jul 30, 2007 10:14 AM
JMD
Jun 27, 2007 04:30 PM
