Will not go into reverse.
Old Oct 9, 2014 | 08:52 AM
PNYXPRESS's Avatar
PNYXPRESS
how mechanically inclined are you? if you are comfortable doing so, pull the shifter off and see if it is working correctly off the trans.
Old Oct 15, 2014 | 06:45 AM
Daehawk's Avatar
Daehawk
You thinking its the linkage PNY? My first car somehow got 2 gears at once in the linkage. I had to remove the shifter and manually use my finger to set it.
Old Oct 15, 2014 | 08:32 AM
R.A.M.'s Avatar
R.A.M.
Hi: I had the shop at my college check the shifter, they said it was working properly.
Old Oct 15, 2014 | 04:36 PM
PNYXPRESS's Avatar
PNYXPRESS
Drain the fluid look for pieces. Something is jamming the reverse shifter rod from moving the gears.
With the fluid drained go under the car and move the tail shaft back and force to try and dislodge the blockage. You may need to have someone in the car trying to put in reverse while you do this.
Old Apr 28, 2015 | 10:23 PM
sonicblue2002's Avatar
sonicblue2002
I second what Daehawk said about the linkage. I had that happen after I did the clutch in my car. It was doing almost exactly what you described, just with second gear.
Old Apr 28, 2015 | 10:47 PM
jwog666's Avatar
jwog666
if its not fied by now it will never be,........very old thread
Old Feb 27, 2021 | 01:52 AM
JDICKENS97's Avatar
JDICKENS97
I get this is an old thread. But did anyone by chance figure out the issue? My 02 is doing the exact same thing his was..
Old Nov 11, 2021 | 05:18 PM
Siverstangsoldier's Avatar
Siverstangsoldier
Did you ever figure it out? I have the same issue!😕
whosniffedme
Jul 12, 2012 01:23 PM
Ze2222
Aug 4, 2009 10:46 PM
1990mustanglx
Mar 1, 2006 11:39 PM
CobraSvt99
Jun 19, 2004 01:08 PM
hoov7472
Mar 31, 2004 11:54 AM
