Boost gauge done!
RE: Boost gauge done!
Flap I am also in Colorado ... I am in the boulder area just north of denver so I am at an even slight higher altitude. I am think of dropping in a Procharger within the next year and I am real curious about the problems you are seeing when the temp drops.. at what temp do you begin to notice problems and how is it manifested... what do you mean you put it in nuetral and then restart? are u saying the problems are intermitten...
Sorry for bombing with questions I am just interested in our altitude/temp problems with blower
thanks!!
thanks!!
ORIGINAL: screaminyellin6
LOL - yeah that could be scary!
That will be a sick ride if you take it down to sea level - hope you keep a socket wrench and pulley in your trunk - lol... Luckily I'm pretty much at or slightly above sea level. I had heard about the temperature affecting the s/c from MSP as well. Looks like it had the same effect of Vortech.
The Guy I rode with said it was 7# pulley - but his gauge went up to 8.8# at one point... Might have just been a goofy gauge and they are never really 100% accurate you know....
All in all it was a sickly ride and loved it - now my kit goes in next week and hopefully done by the weekend !!! YIPPEEEYYY I can't wait to see how the automatic handles it. I'm also having it custom tuned using SCT instead of Diablo - should be fun We already have a basic tune to start with that the shop has so I'll be sure to let everyone know of the progress
This is definitely something to keep in mind when you're shopping for forced induction.
All the more reason to make sure I have that wrench with me! I definitely do not want 11-12 psi on this engine... at least for a few years!
Oh yeah, I have a sweet article on our hypereuctic (sp?) pistons which I'll scan and post soon. Very good info and insight as to why Ford uses them....
ORIGINAL: cman332001
thanks!!
thanks!!
Basically, our car's computers are capable of detecting a "lean" condition during operation. Lean mixtures = greater horsepower, but the extra heat from the bigger 'bang' creates higher cylinder temps, which in turn increases your risk of detonation. By detecting this condition, our cars can help prevent detonation before it occurs. The problem is if the PCM (or whatever Ford calls it) detects this, it throws the car into a "safe mode" not unlike safe mode on your computer. All I do, it put it in neutral so I can coast, shut the car off, count to three, and restart it.
So far, it's only happened at about 10F. This was at about 5500rpm. When the air is colder, it's denser. This denser air helps create the lean condition. Basically, my tune needs to put a bit more fuel in at that rpm range. I don't have the problem above 32F.... so it's probably pretty close to a perfect tune. We'll have to see.
George at RPM Outlet is waiting for my A/F numbers at WOT before he'll send me a new tune. He wants to get it right the first time. I got the gauge in last night, but it probably won't get installed until this weekend when I can take the car to the muffler shop so they can weld in the sensor bung. I considered welding it in myself, but they have more experience this stuff. I've done enough to this car on my own to bite the bullet and let someone else work on it.
Don't worry about asking questions! Sorry I couldn't reply sooner. I understood doing the rearend and S/C myself would bring on a bunch of questions, so keep 'em coming.
Flap thanks for more info on the alt/temp problems you are seeing .. defintely keep me up to speed on how your ride is doing post SC install...Whenever you get a chance to dyno it I would be very interested in the HP / TQ at wheel (what are u guessing you will see there?). At any rate thanks for pioneering this effort, it makes things easy for those that upgrade down the road...
What type of rear-end work did u do? was it necessary due to the SC or was it just about getting more HP to the ground for you?
in otherwords : what else is needed with the procharger ? was it just the prochargerkit/tune and new fuel injectors etc???
again thanks for all the great info!!
@cman
No problem. When I get the tune all straightened out, you'll have to let me know if you're down in the Springs area. I'll take you for a spin!
For the rearend, I decided to stick with the 3.31 gears and go with the Detroit TrueTrac. I did the job myself in about 6 hours. You can check out my install writeup here. Personally, I really wanted an LSD, but didn't trust the Ford T-lok to handle what I had planned for this car. Also, the TT doesn't require a rebuild like the T-lok does.
On that note, I'm really not sure how much HP the stock rear end can take. I know I definitely would not want all that power on one wheel, though....
Really, nothing is absolutely needed with the kit as it comes from RPM Outlet. There are a few things you can do to make it a more "enjoyable" experience, though. Basically, I ended up getting the rearend, boost gauge and A/F gauge on top of the kit. I already had the exhaust done, so that was something I didn't have to worry about. Dual exhaust is not required by any means... but having an S/C is definitely reason enough to get one.
Kool..... I already have the dual exhaust (got it in prep of my future upgrades)... Looks like I will also get the tlock or something more durable like u said to get both wheels hooking up....
if I ever head down there I will check u out... it would be nice to drive or ride in before I invest all that $$$$, only thing is I am not sure I can do all my work myself like u did so I might even spend a little more on prof. install/tune.... do u know anyone in our area that is good... and I wouldn't mind driving south for the right shop....
thanks again!!
thanks again!!
I just created a new thread with my exhaust upgrade from yesterday...
https://mustangforums.com/m_1141511/tm.htm
jwog666
12-27-2021 08:09 PM
Galactic
04-29-2019 02:56 PM
andrew1969
16
01-08-2016 02:48 PM
