performance question - rims
Old Mar 20, 2006 | 03:36 PM
Big Red's Avatar
Big Red
Default RE: performance question - rims
dont bigger wheels mean more workt o get going but less work to cruise?
Old Mar 20, 2006 | 03:42 PM
chidrock's Avatar
chidrock
That's right...I was just asking to see if it would be a big difference when I switch to the 17" rims over the 16"s.
Old Mar 20, 2006 | 03:47 PM
Tres Wright's Avatar
Tres Wright
ORIGINAL: chidrock
Is there a difference between the diameter of the V6 rims & the GT ones? I think the rims are bigger, but the tire is smaller...maybe he's just been giving it more gas to make up for the difference in accelleration?
I'd say it's highly unlikely they are exactly the same diameter. You can look it up on the 'net I'm sure, the tires are P215/65R16 versus 235/55ZR17.
Old Mar 20, 2006 | 03:54 PM
WindVeil05DropTop's Avatar
WindVeil05DropTop
I think I read somewhere that the 17s are 27.18" diameter tires stock, and the 16s are 27.00" diameter stock. Regardless, I made the switch and didn't notice any difference in acceleration, MPG, speedo, or anything. All I really noticed was in turns it feels like I have a little more rubber on the road (which I do). Hope this helps.
Old Mar 20, 2006 | 04:00 PM
chidrock's Avatar
chidrock
Thanks Windveil; more opinions from others who did this helps out. I'm going to just put them on and see what happens. I hope it turns out like you said...
Btw, I looked it up, the 16"s (P215/65R16) looks like it's 27", while the 17"s (235/55zr1z) showed up as 27.18", which was probably rounded anyway.
Old Mar 20, 2006 | 04:17 PM
thatstang's Avatar
thatstang
The stock 16" Alum. rims are fairly light and if you want handeling, purchase some 235/55 tires. You'll achive 2 goals. One is smaller wheel diameter (26.2") which transltaes to differential ratio increases from 3.55 to 3.68 so better acceleration. Second, car is about .4 on inch lower to ground and handles better also because of lower profile.
Ofcourse if you prefer aggresive look over performance, then it is a different story. On my project Civic I switched stock 16.5lb 14" rims with light 12.5lb 14" rims and acceleration improved dramatically. Felt like I gained 5-7hp at the wheel.
Just to save you some money and aggravation :-)
Old Mar 20, 2006 | 05:01 PM
beltone's Avatar
beltone
I just put on some GT wheels from Saleen $375 plus shipping. The outside Diameter is the same.The handling is way better plus "Z" rated tires,lower profile. If you put lower profile on stock wheels it would throw your speedometer off. You can't beat the deal from Saleen. I put my stock spinners on the Bullit wheels and they ride and look great !!
Tivo304
Aug 28, 2023 12:19 PM
whatsup62
Oct 16, 2015 03:07 PM
M3hunter
Sep 5, 2015 03:42 PM
The01Cav
North East
Sep 5, 2015 03:39 PM
cbird1177711
Sep 2, 2015 08:51 PM
