picture of camber bolts
if you look closely you can see the lobe ont he shaft closer to the right turning the lobe certain amounts adjusts your camber , max adjusted camber is at the tip of the lobe
RE: picture of camber bolts
here is what i used
http://www.2005stang.com/viewtopic.p...567#9556781260
EZ CAM XR (14MM)
The new EZ Cam(tm) XR is designed for non-slotted struts. It allows both positive and negative camber changes up to approximately 1.75 degree (depending on vehicle) by replacing the upper O.E. strut/spindle bolt. This easy to use adjuster provides built-in adjustment over the life of a vehicle just by rotating the head of the bolt. Each kit contains two cam bolt assemblies, enough for both sides of the vehicle. MasterPaks of 10 are available.
[IMG]local://upfiles/14019/65FB4A47EC594E55A060D128B684DAAA.jpg[/IMG]
[IMG]local://upfiles/14019/A1BA048A878E42C9B692E126E0212984.jpg[/IMG]
EZ CAM XR (14MM)
