I'm thinking about getting this turbo...
Old 06-17-2006, 05:22 PM
Backlash
Backlash's Avatar
Default I'm thinking about getting this turbo...
http://powerhouse411.com/catalog/ind...products_id=51
What supporting mods will i have to get?
Please post exhaust, suspension, and transmission mods. <<<I want all.
Thank you for your time. I'm a noob.
Backlash is offline
Old 06-17-2006, 05:36 PM
rygenstormlocke
rygenstormlocke's Avatar
Default RE: I'm thinking about getting this turbo...
ORIGINAL: Backlash
I would get the intercooled kit, that is what I have. I also suggest the following:
-A pillar or some sort of gauge pod
-boost gauge
-AEM wideband gauge (just started the install on mine)
-LSD
-Gears (optional, I'm going to give the 3.73's a try, then drop down to stock gearing like PH did)
-Lower control arms
-Upper control arm
-better/wider tires, I'm running Nitto 450's 275/50/17 in the rear, 255/50/17 up front, though some of the members on the board got me thinking about the 555's LOL
For exhaust, single is fine with this kit, really isn't a need for duals except for sound. I'm running dual Flowmaster American Thunders. Maybe get a nice Axleback muffler, like MRT, Ford Racing, single Flowmaster AT, Magnaflow, JBA, etc.
rygenstormlocke is offline
Old 06-18-2006, 05:34 PM
Backlash
Backlash's Avatar
any other opinions? i would like more than one...although i do respect rygen.
Backlash is offline
Old 06-18-2006, 05:47 PM
defiant00
defiant00's Avatar
The gauges and pod are definitely needed, when I go F/I I'm going to use a total of five gauges: Boost, Fuel Pressure, Oil pressure, Oil Temp, and Wideband A/F. The more info you have about the car the better. At a minimum I'd go with a boost and Wideband A/F like rygen said. You may want an EGT, or Pyrometer, gauge as well to measure the temp of the exhaust gas entering the Turbo.
Down the road you'll want to consider beefing up the bottom end of your motor, things like forged pistons, rods, etc. if you are going to try to run more that minimal boost. New head studs aren't a bad idea either. You don't want a blown head gasket!
defiant00 is offline
Old 06-18-2006, 05:58 PM
Agleon
Agleon's Avatar
Intercooled kit.
Edit: rygen covered that already.
Agleon is offline
Old 06-18-2006, 07:31 PM
blackfoot
blackfoot's Avatar
well if you gonna run high boost, your gonna want lower compression.. now a quick fix, and i dont know how valuable this will be , but you may be able to keep your top end (pistons and connecting rods.. ( our crank is already forged if im not mistaken) if you run a thicker headgasket with a better composite of metrials, (a gasket made for boost in laymens terms). the thicker gasket will lower your compression youll be able to run safer higher boost with less stress on the motor, and with arp studs youll be able to torque down that head so youll never get blowby (boosts worst enemy with stock gaskets)
blackfoot is offline
Military_man_88
12-02-2015 10:20 PM
firecoyote
09-27-2015 02:37 PM
GimpyHSHS
09-18-2015 12:27 PM
robjh22
Suspension
09-08-2015 12:47 PM
vintageaion
09-08-2015 10:45 AM
Quick Reply: I'm thinking about getting this turbo...
