water pump TECH HELP
Old Jul 8, 2006 | 04:49 PM
armycook1981's Avatar
armycook1981
Default water pump TECH HELP
hey i have a bolt broke off insde my water pump pulley.. ANd i think i might have damaged it cause the other 3 bolts will losen up every once in awhile and cause a knovking noise. WILL the v8 one work on ours .. is it the same.. i was looking at the v8 PH elec one. please any help would be great,
Old Jul 8, 2006 | 05:30 PM
afixer's Avatar
afixer
Default RE: water pump TECH HELP
4.0 water pump
water pump 4.6
here ya go they do look diferant
Old Jul 8, 2006 | 07:17 PM
armycook1981
yeah fazm said the 4.6 is a mod motor... I have the bolt stuck in the housing .. dont know what to do to get it out
Old Jul 8, 2006 | 09:27 PM
TNT1968's Avatar
TNT1968
You might try an easy out to get the piece of bolt out or take the water pump off to get the bolt out. At worst you'll have to replace the water pump and pulley and one bolt.
Old Jul 8, 2006 | 09:30 PM
afixer's Avatar
afixer
you have to fix it at the high rpm's the out of balance shaft due to the missing bolt will trash the pump
Old Jul 8, 2006 | 11:26 PM
armycook1981
do you know how tom?
Old Jul 8, 2006 | 11:42 PM
afixer's Avatar
afixer
so the broken bolt is it one of the four that hold the pulley on? maybe there is some tread sticking thru the back and you can grab it with some pliers and remove it from the rear,
Old Jul 8, 2006 | 11:45 PM
TNT1968's Avatar
TNT1968
If a piece of the bolt is sticking out where you can get some vice grips on it with the pulley off you're home free. Then you will just need the one bolt to replace that one but it may be wise to replace all of the bolts. You'll have to loosen the other three bolts somewhat ,release the tension on the belt tensioner with a 1/2" ratchet or breaker bar and take the belt off of the pulley. Then by hand take the other bolts out. Get the other bolt out and replace with new bolts. The diagram that Afixer supplied should tell you where the bolts are for the water pump if you need to replace the pump.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
