tail light?
Mine blew out too but you can't buy this bulb in any autoparts store I found. I had to take mine to the dealer and get it under warranty. BUT, to answer your question, you need a flat head screw driver and a 10mm wrench.
There are two push pins holding down the plastic molding on the side of the the truck latch, then use your flathead to remove the torx bits on each side, then the light come out using the 10mm. Be sure to support the light as you are wrenchinging it out, it can come loose and land on your bumper and scratch it.
okay well here it is i got the pictures and i fixed the tail light easy
i just did a temporary fix but i need to buy a new bulb
here are the pictures of the cf hood
http://www.putfile.com/pic.php?img=3213864
http://www.putfile.com/pic.php?img=3213859
http://www.putfile.com/pic.php?img=3213846
sorry abotu the repeated posts i was having some trtouble with the html my host is retarded you just gotta go there :
jwog666
Dec 27, 2021 08:09 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
folivier
Tennessee Regional Chapter
Oct 2, 2015 05:32 AM
haha ohw ell i need to replace it i just dont know how to get to the thing
