GT-R Hood
GT-R Hood
hey guys, i bought what i thought to be the worlds COOLEST hood, i got it putiton and it looked it woudd fit perfect, i had it painted, got it back put it on and screwed it in only to have the front sit to far back, and the back sit to far down! any help or advice you guys could give me would be awesome!
RE: GT-R Hood
When you do body work you have to align all the panel so that they will matchup with the lines of the car. How does that look? How tight did you make the hood bolts? You might have to shim the hood Play with it and see. Also not every aftermarket peice is gonna fit perfectly out of the box there are to many factor involved. It could just be the hood too. I would check out the allignment of the hood first play withe the bolts someget it where you want it and then you mey have to get washers to shim it up so everyting is tight.
