Mod Question?
Old Aug 22, 2007 | 08:17 PM
Sancho805's Avatar
Sancho805
Default RE: Mod Question?
from what i understand, exhaust will not affect a tune. a tune will only adjust what comes in, not what goes out. but then again, i could be wrong.
Old Aug 23, 2007 | 12:48 PM
07lane40's Avatar
07lane40
hey wickerbill, how did you fit the dual 12" kickers in your trunk? i have a single 12" L7 and i had to take apart the latches on my trunk to just fit the one in there! do you have a custom box? and what speakers do you have to balance the bass out? ill assume youre running the 1500x1 kicker amp cause thats what two of my buddies are running. im wanting to make the step up to dual 12'swith a custom box, but i dont want to unless i know what other speakers im gonna need, and what amp to run thru the speakers. right now im just on the 750.1 thru my sub and the 350.4 throough 5x7 polks.
any help would be greatly appreciated. thanks.
Old Aug 23, 2007 | 03:06 PM
Wickerbill's Avatar
Wickerbill
I custom made a sealed enclosure w/ 1 cb.ft for each sub. Kicker reccommends .88 cb.ft for a min. I used 1/2" MDF and Fiberglass made it mirror smooth and painted alloy. I unhooked the factory 4x6 in the rear deck and used those wires for my feed to line converter to my amp. It is a Linear Power 4440 hand made in California. I didnt install any other speakers, the Shaker 500 speakers up front were plenty enough to keep up with the subs. I use a Kenwood Eq on my sub to balance it out with the rest of the system, the eq has a 100Mhz low pass x-over made into it. 1 farad cap is plenty enough to protect my electronics on this setup. I suspect you have a band pass box and my whole system takes up less room than a store bought band pass.
Old Aug 24, 2007 | 01:10 PM
07lane40's Avatar
07lane40
what cost did that setup run at? (just the box)
Old Aug 24, 2007 | 01:28 PM
Wickerbill's Avatar
Wickerbill
I had close to $150 in materials and about 10 to 12 hours labor from start to finish
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
Roush05
Sep 10, 2015 12:23 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
