What springs would drop my car half an inch?
I want to do a drop, but not a big one as anything above an inch I see as horendously tacky. What springs would drop my v6 the magic number?
Furthermore I'm going to be putting in a 1 peice carbon fiber DS at the same time. I've heard that I need a new Panhard Bar and a new set of rear Upper Control Arms that are adjustable. Is this true?
RE: What springs would drop my car half an inch?
ORIGINAL: Legion5
http://mrt-direct.com/concept/Suspension/2005.php
I hope some one gets to my second concern soon, and that selection is awesome!, except I would prefer like 3/4th's all around instead of slighly lower up front.
Other than that I'm also worried that it mentions the springs are harder than stock, I don't want a bone hard ride.
Finally let's add a 3rd question into the mix, can I safely paint red springs blue?
For the record my v6 is as heavy as the GT due to having the pony package. This means it will sit slightly lower than most v6's.
ORIGINAL: Legion5
You're a slight bit heavier than a non-Pony 4.0 due to the swaybars but they're only partially sprung weight, and the bigger wheels and tires, but they're totally unsprung weight.
Less than an inch drop probably won't require an adjustable panhard bar, and there's only one upper control arm.
ORIGINAL: Torch_Vert
For the record, no it isn't, unless your Pony Package included the 4.6L V8....
ORIGINAL: Legion5
Yeah it's about 13 lbs lighter as independently measured, I've installed a few weighty mods that I am sure weigh about 20 lbs so I beleive I am at the same weight.
I've heard of people using adjustable panhard's for less than 1 inch drops though... but I suppose the key is, will I need a UCA with a on peice DS and a less than 1 inch drop?
I still think it's pretty ammusing that our suspention moves up and to the left instead of just up. Though I can find no possible idea that would allow the setup to work without doing this.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
