JBA headers, shipped to your door, for 320!
RE: JBA headers, shipped to your door, for 320!
ORIGINAL: ODDYSEY
So here is a noob question... what bonus do headers give you?
1.) Larger diameter tubes than stock means more flow.
2.) Quality headers like JBA have equal length tubes
3.) Stock manifolds and headers have rough edges from the casting process, aftermarket headers polish the tubes inside and out, same as polish job on heads, making the exhaust gases flow through with no restrictions or changes in velocity.
4.) Ceramic coated headers dissapates the heat off the exhaust evenly and more effeciently than stainless steel or cast
5.) More flow equals more sound, exhaust sound is helped tremendously with header upgrade. Also the flow leaving the aftermarket headers will improve the vaccum of exhaust gases out of the cylinder and through the exhaust runner more effectively.
Hope this helps Oddysey!
what would a shop typically charge to install some headers?
ORIGINAL: Wickerbill
On our cars with all the room under the hood I wouldnt charge more than 2 hrs to install headers. Typical labor rates here range from $50-$70 hr.
ORIGINAL: ODDYSEY
Yea it does, I was familiar with several of those, but I just didn't think it would make a noticable difference on our 6's.
If you added more air in, as in a CAI, a tune, larger MAF sensor/throttle body you may derive some benefit from headers. But just to through a set on and expect results probably won't happen.
But, I like headers, I like the sound of headers. So by all means if you want headers go for them. Just don't expect any hp increase unless you're going to make any more modifications to your engine intake.
Ok so do you guys think it's worth doing JBA Headers if your are going to do a CAI and a tuner?
I have dual GT Mufflers now but I was thinking of changing to the JBA Duals with H Pipe what do you guys think? worth it?
worth it or not, ima do it when i gather the funds. improved sound with a little extra pep is good enough for me. its also peace of mind that there is less stress on the engine. JMO.
09-25-2015 06:58 PM
