stroker kit
Old Jan 20, 2008 | 09:01 PM
cvz_finezt's Avatar
cvz_finezt
Default stroker kit
i know morena motorsports has a 4.5L stroker kit of the 4.0 ohv. so i emailed them about fitting the kit of the ohc engine. so still waiting on an answer. i remember reading on this forum tht they were not going to make the stroker kit for our cars. i could be wrong.
Old Jan 20, 2008 | 09:14 PM
chrisc's Avatar
chrisc
Default RE: stroker kit
they are not making one....well at least it has been "coming soon" for about 3 years now
Old Jan 20, 2008 | 09:18 PM
cvz_finezt's Avatar
cvz_finezt
yea thts wat i kinda figured. myb i should buy it and find a way of modifying it to my engine.
Old Jan 20, 2008 | 09:33 PM
chrisc's Avatar
chrisc
ORIGINAL: cvz_finezt
If you want to have a power n/a engine, you might want to look at a full SSM engine with a 10.0:1 ratio. A built engine with 8.8:1 with the stock intake made 201rwhp/216rwtq. With a 10.0:1 CR and an intake, you could probably hit the mid 200rwhp level (which I am guessing is what you are looking for).
Old Jan 21, 2008 | 09:54 AM
Ken04's Avatar
Ken04
in lieu of a kit, it's still possible to increase stroke. Hot rodders have ground down the rod journal on the crank, and/or used pistons with a wrist pin closer to the crown of the piston and longer rods.
Boring the cylinders is the obvious way to increase displacement also. Maybe a slight overbore with longer rods since you have to replace the pistons anyway ?
Just a thought. Good luck.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
