Vacuum Leak?
Old 06-12-2008, 04:58 PM
07redMustang
07redMustang's Avatar
Default Vacuum Leak?
Sometimes after I drive my car for 10+ minutes and shut it off I get this hiss under the hood. IT hisses for a good minute or so. Is this a normal sound or do I have a small vacuum leak somewhere? I've tried to pinpoint the location of the hiss but I can't seem to find it anywhere.
07redMustang is offline
Old 06-12-2008, 10:53 PM
BM83
BM83's Avatar
Default RE: Vacuum Leak?
are you running the a/c when it happens?
BM83 is offline
Old 06-12-2008, 11:07 PM
Favre4TD
Favre4TD's Avatar
Im pretty sure if the motor is off you cant have a vac leak
Favre4TD is offline
Old 06-12-2008, 11:54 PM
07redMustang
It does it if the ac is on or off.
Isn't there still a vacuum even when the motor is off? I know there isn't anything producing the vacuum when the car is off but isn't it still there shortly after you shut off your car?
Old 06-13-2008, 12:11 AM
blackstang14
blackstang14's Avatar
When I had a vacuum leak after installing the X, the sound went away as soon as I turned off the engine. It was more of a high pitched squeal than a hiss. I have heard that hiss before and it is usually after I am running my AC.
blackstang14 is offline
Old 06-13-2008, 12:24 AM
07redMustang
Okay I will see if it does it when I only run the ac or not.
Thanks
Old 06-13-2008, 08:26 AM
Steven6095
Steven6095's Avatar
Mine is hissing too!!!!!!!
I will tell you now it is not AC related. Drove the other day with the windows down, no AC - pulled into garage, shut it off and hissing.
Steven6095 is offline
Old 06-13-2008, 09:07 AM
157dB
Cut & Paste Expert
157dB's Avatar
Its the compressed freon going thru the orifice.
There is still pressurized freon after you shut off the motor.
There is no manifold vacuum after the engine is shut off.
There is vacuum in the brake booster after the engine is
shut off.
Do you have a still pedal after the hissing stops?
If they still act like power brakes once or twice after
the engine is shut off after the hissing stops then its
not the power booster.
If they are very hard after the hissinf stops and the engine
is off, its a leaky brake booster or vacuum check valve.
157dB is offline
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
jerrytubes
10-23-2015 12:11 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: Vacuum Leak?
