any suggestions on cutting rear v6 bumper?
RE: any suggestions on cutting rear v6 bumper?
the plastic is kinda thick to do it by hand...i did mine with a rotozip/dremmel tool.....got the template from frpp...make sure your printer is set at 100% size....
http://www.fordracingparts.com/downl...tM-5230-V6.pdf
I did my cut with a box cutter/carpet knife. Although I did dril several small holes along the cut line to help keep it fairly straight. After I took a wine bottle and wrapped sand paper around it to smooth out the edge.
From what I understand, unless you are using the inserts for the bumper cut out that is included in the FRP, the hole will be too big.
If you aren't getting the Ford V6 Conversion Kit, then use this template below. Many of us here used this to make the cut;
http://pysales.com/inst/SFM68-bumper-cutout02.pdf
ORIGINAL: JimC
A wine bottle wrapped in sandpaper is nice to
finish sanding the radius to near perfect round.
jwog666
12-27-2021 08:09 PM
