V6 Turbo
V6 Turbo
Well I am getting ready to get heavy into the turbo project. I'm either ordering all the parts seperate or a kit.
Any advise would be great.
And preferably a checklist for ordering the parts seperatley thanks :-).
A lot cheaper to build your own if you have the know-how. I'm building my own and slowly buying/building part by part.
As for a parts list, you'll need to expand this on your own.
Hot Side:
-Turbo
-Wastegate and pipes
-Hot side piping for exhaust, to turbo and downpipe
Cold Side:
-Intercooler
-Either a BOV or CBV depending on which setup you go with
-Cold side piping
-Clamps and cupplers
Oil/Fuel/Vac
-Oil feed and return lines
-Vac hosing
-Breather hose for valve covers
-Fuel Injectors
Gauges/Tune:
-Handheld tuner
-Dyno Tune of course
-Gauges of choice if desired
Supporting mods:
-Rear end is a must I would say, rest is up to you
Good luck.
Hot Side:
-Turbo
Cold Side:
-Intercooler
-Cold side piping
Oil/Fuel/Vac
-Vac hosing
-Fuel Injectors
Gauges/Tune:
-Handheld tuner
Supporting mods:
Good luck.
you can go with the sts but at 9psi it falls short of other turbokits out there by a pretty good amount powerwise.
also im not sure but i thought the sts kit was around 5k? which makes it right about the other kits pricing.
