Is this normal?!
Old Sep 8, 2008 | 10:48 AM
maxshuty's Avatar
maxshuty
Default Is this normal?!
When I put my car into Park it has to roll quite aways and then it makes a "Clicking" noise (thats how I know when its in park). Should it be doing this? Because if I'm on a small hill or anything like that I probably roll a good 3-6" before it clicks.
Is this normal? If not, what could be wrong?
Old Sep 8, 2008 | 10:51 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
It is normal in an automatic, there is some play before it locks in. If it bothers you just put on your emergency brake. Mine does it every time
Old Sep 8, 2008 | 10:57 AM
maxshuty's Avatar
maxshuty
Ok thanks! Also, is it really hard on the car if I let off the brake quickly if I'm parked on a hill or something and it rolls into that too fast? (I usually ease of the brake ever so slowly, but sometimes I dont think and let the brake out and it rolls into that "Click" really fast.)
I did just use my Emergency brake for the first time about 20 minutes ago. When I turned my car back on it started up kind of funny (made a screeching noise)
Old Sep 8, 2008 | 11:09 AM
157dB's Avatar
157dB
Cut & Paste Expert
Its the parking pawl that is engaging a toothed wheel on the output shaft of the tranny. Its spring loaded and it should jump into the first
available slot, not pass up a few slots before finally engaging.
Page 307-01-11
I would check your transmission shifter adjustment for proper
operation.
307-05-7
Old Sep 8, 2008 | 02:55 PM
.boB's Avatar
.boB
They are correct. But, it's kinda bad for the transmission. It puts the entire weight of the car on that pawl. When you shift into gear to get started, you have to pull those teeth apart under the weight of the car.
The best way to prevent wear is to set the parking brake, take your foot off the brake pedal, and then shift into park.
Old Sep 8, 2008 | 04:07 PM
mustangfan410's Avatar
mustangfan410
The 2014 Mustang Forums T-Shirt Design Winner
its normal
Old Sep 8, 2008 | 06:26 PM
Lethaldosage423's Avatar
Lethaldosage423
If your on a hill put on your E brake so your not resting on the gear that way when you go back to drive, you will have a smooth shift.
thats the only time i use the E brake
Old Sep 9, 2008 | 10:49 AM
So_Cali's Avatar
So_Cali
Good, I thought I was the only one that was experiencing this... When I put it in park, I always use the E-Brake, on a hill or not. I also noticed that when its in park it shifts a little until it clicks. Wierd LOL
Old Sep 9, 2008 | 01:57 PM
2005Redfire6's Avatar
2005Redfire6
All automatics do that.
Old Sep 10, 2008 | 03:49 PM
kevinmalec's Avatar
kevinmalec
I have an 05 stang and I used my ebrake in the winter....BAD move. My e-brake froze to my caliper and I had to wait until noon the following day for it to unfreeze. Just a heads up. ;-)
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
