Replacing AC knobs
Old Sep 27, 2008 | 02:17 PM
thuxel's Avatar
thuxel
Not sure if they are the right ones.
I don't think they are. They have a notch in the center that looks like
they are made to fit into.
They seem to work though. No slipping or anything right now.
Old Sep 27, 2008 | 02:47 PM
thuxel's Avatar
thuxel
Looks like the place my wife bought them for is called Dynamic Racing Products,but
they only list them as 05-06 Billet AC *****
Old Sep 27, 2008 | 10:19 PM
StreamlineStang's Avatar
StreamlineStang
So then you got them to somehow work?
Yeah those wouldn't be the correct ones then. 07 and up are designed different.
Old Sep 28, 2008 | 09:14 PM
thuxel's Avatar
thuxel
They dont fit exactly correct. I'll be replacing them, but they'll do for now,
Old Sep 29, 2008 | 08:34 PM
StreamlineStang
Here you go.
The proper AC *****:
http://www.silverhorseracing.com/web...ategory_id=254
Instructions:
http://www.silverhorseracing.com/Ins...%20Control.pdf
Hope this helps!
Edit: Also what part of PHX are you in? Ever go out to Speedworld?
Old May 14, 2010 | 01:46 PM
nmd55's Avatar
nmd55
has anyone tried retrofitting the MGW ***** listed below for an 07-09
http://www.mgwltd.com/mustang2005_billet_ac_knobs.shtml
I made the mistake of buying these without realizing they wont work on my 08.
I looked at the back of the MGW ***** and the stock ***** and they are exactly the same except the stock ***** have a couple of grooves cut in them. I believe i can cut the same grooves in the MGW ***** with a wire cutter and they should work.
If anyone else has done this it would give me more courage to potentially ruin these.
Old May 14, 2010 | 09:39 PM
Twstones's Avatar
Twstones
I just put that set on from SHR. It was a little scary breaking the old ***** off. The most important part is making sure you have all the little pieces of broken plastic dug out of the controls, before you try and put the new ***** on. Look at each **** and see how many little tabs broke off, so you won't miss any. They're hard to see, and I used a straight pin to dig them out. It appears there are three notches that hold each **** on, and if a little piece of plastic get left in there, the new one may not hook on all three notches, and thus won't lock on like they're supposed too. The new one's look great.....Did that make any sense???
Old May 15, 2010 | 10:00 AM
157dB's Avatar
157dB
Cut & Paste Expert
www.motorz.tv
carid
Jul 8, 2016 09:55 AM
5.0muscle
Jan 11, 2016 01:17 PM
9550
Oct 26, 2015 05:01 PM
MusicCity615
Sep 12, 2015 07:05 AM
Art161
Sep 9, 2015 10:33 AM
