Quick offset question
Old Nov 28, 2008 | 01:40 PM
UltraKla$$ic's Avatar
UltraKla$$ic
Default Quick offset question
I'm interested in some 20x9 American Racing Razors that have +40mm offsets.
I fully understand the offset concept BUT I wanna know if the width of the LIP on the outside of the wheel is different on a +24mm offset Razor vs. a +40mm offset Razor.
I know the 40mm wheel is more wheel tucked in under the fender well but does this come at the cost of a smaller outside lip vs. the +24mm offset?
Old Nov 28, 2008 | 02:03 PM
157dB's Avatar
157dB
Cut & Paste Expert
https://www.rsracing.com/tech-wheel.html
Great info.
Cant explain it any differently.
Old Nov 28, 2008 | 04:14 PM
UltraKla$$ic
Thanks 157db
Why would one choose a +24mm offset over a +40mm offset?
Old Nov 28, 2008 | 04:31 PM
UltraKla$$ic
Well, got it figured out. The +24mm offset is to accomodate the Brembo brakes on the GT500's.......that's it. LOL!! The width of the lip doesn't change on either wheel....+24mm or +40mm.
Old Nov 28, 2008 | 11:03 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
I run 24mm offset in the rear and 40 mm offset in the front. It gives my car an old school staggered look. Keep in mind though running a 24mm offset in the rear will make your rear tires stick out a little past the fender, so be prepared to have some d-specs to tight the rear or they will rub.
Old Nov 30, 2008 | 10:19 AM
UltraKla$$ic
Thanks ODDYSEY for the input!
Old Nov 30, 2008 | 01:45 PM
pascal's Avatar
pascal
S197 Section Modder-ator
On a 9" rim?
Tire still passes the quarters?
Damn.
Old Nov 30, 2008 | 04:11 PM
ODDYSEY's Avatar
ODDYSEY
Yea about 1/4 to 1/2 inch out. I had to get an adj. panhard bar because you can definitely tell the difference when your tires stick out.
This view shows how far...
tmdm
May 2, 2021 02:49 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
