Fog Light Bulb Replacement Assistance Needed
Old Mar 31, 2009 | 09:21 PM
Nuke's Avatar
Nuke
Default Fog Light Bulb Replacement Assistance Needed
So changing the fog bulbs on my g/f's V6 Pony isn't as simple as it was to change the bulbs in the fogs in my GT. I unbolted the top of the grill but the fog lamp assembly on the V6 is deeper than the ones on my GT and I couldn't get my hand in there. What's the trick?
Old Apr 1, 2009 | 10:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=391&viewfil...amp%20Bulb.pdf
Its not rocket science. ???
Old Apr 1, 2009 | 01:23 PM
Nuke's Avatar
Nuke
No it's not. But getting the grill out far enough so I can GET to the damned socket seems to be!
Old Apr 1, 2009 | 01:28 PM
MrSandman's Avatar
MrSandman
Originally Posted by 157db
That's a funny little diagram you posted... what it doesn't show are the scrapes on your hands after the switch-out process...
Yes... take off the black radiator cover. Remove the top screws and you have to pull the grill back enough to get to the lights.. it's hard.. but once you get the first one off.. the second will take less than half the time.
Old Apr 1, 2009 | 01:34 PM
afixer's Avatar
afixer
funny stuff, it may or not help but here is a link to when i did my ss center grill install. it basically shows how to remove the grill. but obviously the lights are diff.
https://mustangforums.com/forum/s197...ter-grill.html
Old Apr 1, 2009 | 07:37 PM
Nuke's Avatar
Nuke
Thanks, afixer. That one pic showing the clips should do the trick. I'll be back in Chicago in 2 weeks at the g/f's place and I'll be sure to post after the bulb swap when I return home.
Like I mentioned in my OP, I was able to get to the bulbs on the GT since the housings aren't as deep.
Diode Dynamics
28
May 26, 2022 12:02 PM
MustangHead91
Aug 23, 2015 09:37 PM
inyadreems
Aug 21, 2015 09:10 AM
drumhedd2005
Aug 13, 2015 09:59 AM
dseg
Aug 8, 2015 09:00 PM
