Pypes X pipe....?!
Pypes X pipe....?!
ok so i found a guy locally who is selling his pypes OR X pipe with all the pipes after the X to... but he took it off of his GT, and i have a v6....
so me question is will the GT X and pipes fit my v6? i know that some stuff is interchangeable between the v6 and the GT... thanks guys....
If it doesn't fit you can have it modified to fit at any decent muffler shop. Every setup I've had has required a bit of tweaking on a pipe here and there. In the beginning, the stock Y pipe was cut off when the duals were added. Now when I add different mufflers, in order to get a perfect fit, it seems like one of the pipes always needs to be bent a little. It should fit, or if not, be very close. If it needs adjusted, a muffler shop shouldn't charge you much to get you up and running.
i for sure will, talked to some friends and they are excited to hear how it sounds to, for the time being i am going to hold off on installing the X pipe and just delete the cats and keep my boom tube, that way i can see how open it sounds
