retune needed when battery disconnected?
Old Feb 20, 2011 | 10:31 PM
neo1674's Avatar
neo1674
Default retune needed when battery disconnected?
do you need to retune your car after u disconnect the negative battery terminal?
Old Feb 21, 2011 | 05:16 AM
loaded6shooter's Avatar
loaded6shooter
nope...
Old Feb 21, 2011 | 07:42 AM
Nuke's Avatar
Nuke
No. The tune stays in permanent memory. You may dump data in the adaptive learning, depending on how long the battery is disconnected, which MAY cause some drivability issues for the first xx miles but most people do this on purpose claiming it improves performance. Unless you drive very aggressively all the time, adaptive learning can cause a drop in perceived performance.
I've done it on a few occasions and my butt dyno perceived a minor increase in performance.
Old Mar 11, 2011 | 09:07 AM
brentamis's Avatar
brentamis
Nuke is right. It is stored in NVRAM just as the stock flash would have.
Old Mar 11, 2011 | 02:22 PM
MustangFirstCar's Avatar
MustangFirstCar
Nah man it stays. Just like the stock computer stays.
Old Mar 11, 2011 | 03:26 PM
2007 grimlock stang's Avatar
2007 grimlock stang
Like everyone here says, nope. Actually, you may feel a good 'reboot' once you connect the battery back up. It'll feel like the first time you drove it before the algorithm began factoring in all the voodoo magic variables that it does LOL.
Many of us regularly do this simply for this reason alone.
Old Mar 11, 2011 | 03:54 PM
kevinmalec's Avatar
kevinmalec
NOPE ~ It's unanimous! When I had to replace out my battery, it was like loading the custom for the very first time. =-)
Old Mar 12, 2011 | 09:57 AM
157dB's Avatar
157dB
Cut & Paste Expert
https://mustangforums.com/forum/v6-s...ut-tuners.html
Elcameeeno
Aug 19, 2015 11:19 AM
drumhedd2005
Aug 13, 2015 09:59 AM
defarmer
Aug 13, 2015 06:40 AM
'stangdude
Aug 12, 2015 01:27 PM
UINZWAY
S197 Shelby Section
Aug 5, 2015 10:34 PM
