What else do I need to put on my duals?
I welded mine too, but not until i drove it 3-400 miles, and made sure nothing rattled. It's very tight quarters over the rear axle. Mine was okay, but many people needed to make a couple of minor adjustments, before they got it rattle free.
Avoid the H-Pipe from the GT.
Get the whole sheebang at once.
But be aware, You will loose low
end torque going from a single
2.5" to dual 2.5" pipes.
Putting an OEM GT exhaust together
from pieces can get as expensive as
a complete system DESIGNED for the V6.
http://iihs.net/fsm/?dir=310&viewfil...ded%20View.pdf
Or get the FRPP V6 set-up.
Hmmmm.... well, I have not yet installed the duals completely... I have an X-pipe (pypes) and mids (newtakeoff GT) awaiting the process... but do have a NTO GT muffler on the car.
Didn't notice much in the way of torque loss.... and really.... unless you like roasting the tires off the car... we're not in the <2k RPM range for long....
Perhaps I'll notice it more once the duals are in. Meanwhile, flashed for 93 octane with my X-cal.... THAT was a very noticable improvement all around.
@157db: EXCELLENT link. THANKS.... I've been wondering WTF the P/N is for those "Exhaust Couplers" was for some time now. From the looks of it, to splice in my "stuff", I'll need one of those... and the rear hangers of course.
I find it dubious that you can get the S.S. version from the aftermarket considerably cheaper than OEM from FoMoCo too...
The factory hanger bolts are thread forming so the easiest thing to do here is remove the bolts from the passenger side and use them to form the threads on the drivers side, the holes are already there they are just not threaded. To do this just hold good pressure against your ratchet as you screw the bolt in. Then just pick up some standard bolts the same size and pitch at the local hardware store to replace the ones you remove from the passenger side.
1996cobraconvertible
SVT Forums
13
01-07-2016 04:50 AM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
