Turn Signal Problem
Turn Signal Problem
My right tail light turn signal looks like it is blown. The only light that is out is the 3rd light. I replaced the bulb and it didn't work at all. When I took the bulb out, the connector has some black in and around it like it blew.
Will I have to get a new wire harness for the whole right tail light or can I get a new connector, cut this one off and replace it?
Did you try cleaning the contacts and verifying that you have ~12 volts at the socket? Hopefully the connector isn't distorted from heat (doesn't sound like it). If the bulb blew and caused some damage external to the bulb itself, i'd be scratching my head if there's no indication of damage from heat. But it sounds like yours is fixable.
Yea just play around with it, try moving the bulb around in the socket and try cleaning it out maybe using some electronic cleaner spray, i've used the CRC brand spray before with success, like $7 bucks in autozone.
Worse comes to worse, you may need to file or use a fine steel wool to burnish the contacts. BE SURE THE POWER IS OFF TO THE TAILIGHTS before using anything conductive or you'll be replaceing fuses. You may have had dirty contacts to begin with which will cause a high resistance connection which in turn will generate heat. Also, make sure there's sufficent contact pressure. you can gently pry the contact out a millileter or so on most connectors IF necessary. But test for voltage. An inexpensive VOM can save you a lot of time troubleshooting. I've seen people tear into an electrical problem only to find out they didn't have power at the socket to begin with.
What do you mean by "third light"? If it is the one that is the closest to the middle of the car (#1 being the tail light on the outside edge) then I don't think it lights up with your turn signal (I have the CDC sequentials now so can't check to be sure).
After I cleaned it, it works again! Thank you! I don't know why I never thought to do that. I guess when the first bulb blew, I must have taken too long to change the bulb out and the black burnt part hardened a little so it wasn't touching the metal on the bulb. Thanks again! I'm glad I don't have to buy a whole new wire harness haha
musnicki
09-23-2015 07:11 AM
