Problems with steering wheel
I have an 07 mustang and I've been trying to fix this problem for about 4 months now. Problem: steering wheel is shaking from side to side, it's not pulling one way or the other so I know it's not the alignment. I've taken it to carmax 4 different times they intend to just keep telling me it's the weights on the wheels and send me on my way so I'm not taking it there anymore. I've had the rims turned 180 deg that didn't fix it. It's shaking around speeds of 55-65. I'm wondering if its the tires( half tread still left) or maybe something to do in the steering column.. If someone has had the same problem or can help me to find a solution I would greatly appreciate it! Thanks for your time
I agree with rotating the tires front to rear first. If that doesn't help I would expect that the rotors are warped. You can have them them turned on a lathe to true them up but if they have already been cut then they will probably warp again sooner rather than later. A pair of GT takeoff rotors is a cheap upgrade, you just need the caliper brackets to go with it. Calipers are the same on GT & 4.0 but if the miles are up there then swap them as well as preventative maint.
If the wheels are aftermarket then it is a retaining ring. Take the front wheels off and 2 of the studs will have a retaining ring on them. Take these off. these are used in assembly and are not necessary. Stock wheels have a cut out for them, while most aftermarket wheels do not.
