How to Change out the Stock Speakers ?
Just add a sub! it will change everything! This box looks like it will fit almost any type of sub. and its way cheaper then the JL audio stealth box. I have one with a Kicker CVX and it hammers! It's thick fiberglass but its real light. Like 15 lbs.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=221279116960
I found an open box Kicker Bass Station for $94 at Best Buy. It's not going to rattle your windows, but it rounded out the sound nicely in my car.
I fit it in the same spot where the custom one above fits, and it has the amp built-in so that's all there is in the trunk. I installed it myself in about an hour (having never done anything like that before). I had to pop the back seat out, but didn't need to remove any panels inside the car to run the wires (and no wires are visible). Also the only hole I had to drill was for a place to attach the ground wire. It can use speaker-level inputs, so you just tap into the rear speaker wires for your signal, wire the ground, and run a wire up to the battery. I also ran a wire for a remote control **** for the bass, which I installed inside the center console so it's completely hidden.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
