manual gearbox oil changing
Old 03-16-2013, 08:59 PM
stoneblue
stoneblue's Avatar
This is what I am running in the rear differental.
http://www.amsoil.com/shop/by-produc...-gear-75w-140/[/QUOTE]
If you have a 7.5lsd and you change to the amsoil for the rear dif. do you still need the friction modifier with the amsoil.
stoneblue is offline
Old 03-22-2013, 07:55 PM
stang06lv
stang06lv's Avatar
http://www.amsoil.com/shop/by-produc...mission-fluid/
This fluid is okay for an 06 v6 manual transmission?
Ive got 75000 miles and looking to change the fluid in tranny as well..
stang06lv is offline
Old 03-23-2013, 11:42 AM
157dB
Cut & Paste Expert
157dB's Avatar
Thats the stuff....
If you have a 7.5lsd and you change to the amsoil for the rear dif. do you still need the friction modifier with the amsoil.[/QUOTE]
No, you have a LSD then modifer is needed.
Most 7.5s dont have a LSD from the factory.
If you have one installed them modifier is needed.
157dB is offline
bjdutch2005
03-24-2017 03:38 AM
2007StangV6
01-28-2016 06:09 PM
Brian Emmer
09-09-2015 02:50 PM
Quick Reply: manual gearbox oil changing
