fuel pump issue
Hello guys I'm posting today to see if you guys can help me with a problem I'm having. So randomly after leaving work my car didn't want to start. It had worked before that with out any problem. I was told it was the fuel pump so I went ahead and took it to a mechanic and got the fuel pump changed and a new filter and driver module. So I drove it home perfectly fine. I turned it on and off a few times to make sure everything was good out of 5x it had turned off once at start. This mourning it didn't start at all. Could the fuel pump relay be going bad?
Not enough information.
What do you mean "did not start"? Do you mean, you turn on the key, the engine cranks, but wont start? Or, it wont crank?
When you turn on the key to the on position, not starting, just on, you should hear the fuel pump prime briefly. That tells you the pump is working to build initial pressure.
Is the check engine light on? And DTCs?
TfcCDR
Sep 14, 2015 12:08 PM
zanemoseley
Sep 6, 2015 12:58 PM
