Rough idle?
#22
it seems like this problem could be a million things and if we do not want to spend a big chunk of money might as well just let it go until it becomes a big problem, like stalling or something
#23
I think my problem is solved! I put my new Ford Racing CAI on, with tunes last week (I have another thread about this...). When I took my MAF off the stock hose I noticed the rubber washer/gasket looked kind of weak. I took a toothpick and some high temp RTV and put just a tiny bead all around it. My car is running very tight and does not vary idle now, or at least on 2 trips to work and back. Maybe that could be your problem? My car just feels different, like there is no variance in idle, and seems much more consistent. I wasn't thinking about sealing that at all while driving, but I thought to myself, man, this thing is running better than it has in a while. Then I remembered I sealed that MAF and pretty much decided then that was almost definitely what my problem was. So, with the new CAI, tunes, and that sealed, I think my problem is solved!
#24
#25
Update - my car did it again. And you know what I'm thinking? When you go to stop, all that gas rushes forward. My car was on the empty side and really did it worse than normal. I am going to try a new gas cap.... anybody on the forum know if this would be a behavior of a gas cap that isn't sealing good enough?
#26
hey so i bought a obd2 scanner and i have 2 bad 02 sensors that could be the problem from what i googled. Then it has a preliminary code of P0456-Powertrain. its a evap emission control leak, very small leak, says could be the gas cap not sealing but i doubt thats causing the rough idle
#28
jrylander1
02-13-2016 11:47 AM
02-07-2016 09:56 AM
02-04-2016 02:00 PM
