we have a problem
Old 09-23-2008, 01:35 AM
  #21
mstngsule68
mstngsule68's Avatar
Originally Posted by Jazzer The Cat
92, I am referring to the OP's New Edge. A 275 is REALLY pushing the Fox Body, but can be done, I am told. I think 88Mach1 is running a 275 up front, but not positive.
Either way 92, get your own thread, I'm workin' with echarlemagne
Jazzer
no he has em in the rear. trust me i know im friends with him.
mstngsule68 is offline
Old 09-23-2008, 07:33 AM
  #22
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Originally Posted by echarlemagne
yup they all the same size
Happy to help, but need more that one sentence replies, please
Did you try the tape on fenders and on liner behind and drive it? Do you see ANY damage on either side of tire or wheel? (you will likely have to remove them to get a good look) Is the vibration at high speeds? Only up a hill at high speeds? Did you do ANY other work besides wheel/tire install reciently? Jack the car up and rotate the wheels, do they spin straight?
I cannot drive the car or look at it in person, so look closely for contact points between wheel/tire and fender.
Jazzer
Jazzer The Cat is offline
Old 09-26-2008, 02:34 PM
  #23
echarlemagne
echarlemagne's Avatar
alright, all that stuff you just mentioned ill try, the tape thing i did already though. they get damaged but not TOO bad, especially when i do u-turns... and that vibration happens when im doing slow turns, i feel some kind of vibration from the bottom of the car, i wonder what it is.... thats whats bothering me right now, the rubbing when i turn isn't too much of a big deal its that vibration thats getting to me! aahhh i'm really thinking of just selling these things and going back to my stock wheels
echarlemagne is offline
Old 09-26-2008, 04:23 PM
  #24
Jazzer The Cat
Retired Moderator
The vibration sounds like a suspension issue. If it were related to tires/wheels, it would likely get worse at higher speeds. I am thinking ball-joint or control arm, but referr this issue to Performance Handling section as many over there have very good knowledge on suspension. It is primarily an S197 section, so may encounter some resistance (RadioFlyer) by some.
Jazzer
Old 09-27-2008, 11:27 AM
  #25
echarlemagne
alright... thanks for all your help
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: we have a problem
