02 GT: 18x9 +30 offset, fit?
Old 03-18-2009, 03:51 AM
Nrre
Nrre's Avatar
Default 02 GT: 18x9 +30 offset, fit?
will they fit?
i noticed on Tirerack most x9's were +20-22 offset.
Nrre is offline
Old 03-18-2009, 08:05 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
That will fit, but +24mm is a more standard off-set for the New Edge rides.
We're talkin' less than 1/4" deeper, but I suppose you may rub a tiny bit on the inside, but REALLY doubt it. Worse comes to worse, you could run a very thin spacer like a 1/8"~1/4" up front. Will fit on the rear and don't see any rubbing issues whatever.
HTH
Jazzer
Jazzer The Cat is offline
jwog666
12-27-2021 08:09 PM
mustangheaven
01-03-2016 11:20 AM
BeatnikFink
10-01-2015 08:00 PM
fastbackford351
10-01-2015 12:24 PM
mdg
10-01-2015 07:04 AM
Quick Reply: 02 GT: 18x9 +30 offset, fit?
